1993 Toyota Pickup Transmission stick will not shift to sel
1993 TOYOTA PICKUP
177,096 MILES • 6 CYL • 4WD • AUTOMATIC
VICFAUST
Appears that when the driver was stuck in the snow on the farm, the tranny stick jammed, is there a way to quick fix this or is it a major tranny change out?
updated 3/5/09
Thanks for your email, I called our home town Toyota dealer and they were very helpful and adviced to check a couple of items: rear brake lights & knob on 4x4 drive on council.
Mar 3, 2009 at 8:55 PM
MMPRINCE4000
  • 8,548 POSTS
Most likely the linkage was broke/bent/knocked out of adjustment.
Raise car, put on stands and inspect linkage on trans. Have someone try to move shifter while you observe the linkage movement.
Mar 3, 2009 at 11:22 PM
