1993 Toyota Pickup Timing gear
1993 TOYOTA PICKUP
145,250 MILES • 4 CYL • 2WD • MANUAL
WALTZ4
When replacing the timing chain and gears do you put the dot on the cam gear at 12 o'clock or
the notch that fits on the cam dowel at 12 o'clock ? The manual says the notch but it runs rough and cannot get the timing to set at 5*.
Sep 30, 2010 at 2:34 AM
Put the engine no.1 piston on its compression stroke/TDC then line all the markings up at the cam and crank sprockets
Sep 30, 2010 at 2:54 AM
