1993 Toyota Pickup ticking
189,500 MILES • 4 CYL • 4WD • MANUAL
JESSEG1985
Especially when I get between 2000-2500 RPM I hear this ticking or poping noise. There also is a problem when going up hills when I shift, it doesn't want to go into the next gear right away and it revs up then shifts. Thanks for your help.
Apr 17, 2010 at 3:46 PM
  • 75,988 POSTS
Sounds like you need to replace the clutch assembly
Apr 19, 2010 at 9:39 AM
