1993 Toyota Pickup Stopped running won't start
190,000 MILES • 4 CYL • 2WD • MANUAL
TJHENSON
I have a 93 Toyota pickup with a 22RE engine. It had been making a ticking sound sometimes at lower RPMs. It stopped running and would not start. It starts to turn the engine and then stops. I have been told that it is the timing belt but I didn't hear any "bad" noises when it stopped.
Sep 8, 2010 at 6:30 AM
  • 75,988 POSTS
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Sep 8, 2010 at 5:08 PM
