Greetings,
This truck will start up and maybe run for 10 minutes and then seems to cut off even before slowing down. It like the fuel shuts off.
If I'm lucky enough, it will run again for awhile and do the same thing. It sat one year and its been used now about two weeks with no problems until this started.
A person suggested replacing fuel filter, i replaced it and knew it wasn't it once it was off, but replaced it anyway. i checked the air flow meter over the air filter and according to specs, it appears ok.
I feel, i'm losing my pump, but not sure. I was told to pull the tank, but something in me says its some other electrical control or sensor keeping it off after it warms up.
i appreciate any direction to take,
Thanks,
Bruce
Thanks,
Bruce
Aug 30, 2008 at 8:05 AM
