1993 Toyota Pickup Oil pressure
189,900 MILES • 4 CYL • 4WD • MANUAL
JESSEG1985
When I am at a stop and just idling my oil pressure drops down into the low range, then when I start to go, the pressue goes back up to normal. I just changed the oil and filter and everything is on tight and the dipstick shows enough oil. Could it be because I used to light an oil (10w-30), should I have used something heavier like 15w-40?
May 9, 2010 at 12:35 PM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge the gauge/oil pressure switch could be misleading you
May 9, 2010 at 3:41 PM
