1993 Toyota Pickup Low compression in cylinder #1
20,535 MILES • 6 CYL • 4WD • MANUAL
JERRY MADDOX
Compression in cylinder 1 is 130, the other cylinders read 150+. Mechanic suspects a cracked ring.
How can this be fixed and what would be the cost?
May 15, 2010 at 8:45 AM
  • 31,937 POSTS
Hi there,
If this is a ring problem the engine will have to be dismantled to do it, as for cost, this will depend on how far you take the job, with the engine stripped you should be doing bearings as well, and with broken rings you may have a scored bore that will need attention as well, so i would be doing a wet comp test first to prove that this is a ring problem to start with.
mark (mhpautos)
May 15, 2010 at 11:19 AM
