1993 Toyota Pickup Help
1993 TOYOTA PICKUP
220,000 MILES • 6 CYL • 4WD • AUTOMATIC
SHAWNCODY
radiator hose blew, truck died, tried starting it to put water in to find leak, wouldn't start. pulled the plug, no spark. changed distributor, distributor cap, rotar, still no spark. tested the coil, it's getting constant power, tested other cars, when you turn the key the tester light flickers. mine stays constant. changed coil and ignitor still no spark. i don't see any fuses that run to these that are bad. what could be the problem?
Jan 2, 2010 at 9:15 AM
tested the coil, it's getting constant power, are you refering htis as battery voltage to the coil or the secondary surge voltage? Did you check the ignition fuse?
Jan 2, 2010 at 9:28 AM
