1993 Toyota Pickup FUEL
1993 TOYOTA PICKUP
291,000 MILES • 6 CYL • 4WD • AUTOMATIC
SUNSHINE7
I have a 1993 toyota truck that has been parked for 3 yrs. Their was no fuel in tank. I put 4 gallons in tank and it is not getting fuel to intake. Can I prime or use starter fluid. will this create a vacuum to pull fuel??
thanks
arnold
Mar 25, 2008 at 5:45 AM
Try priming it with starting fluid and see what happens-when it does start check the fuel pressure.
No start while priming it-its coming from the ignition system look for spark
Mar 27, 2008 at 9:36 AM
SUNSHINE7
It will start when using starting fluid. Its not getting fuel to the intake. I removed the fuel line at the intake and their is nothing. Should I check the EFI fuse and if so how do I do that?
Thanks
Mar 28, 2008 at 2:48 AM
Check the fuel pressure to rule out the fuel pump-
BTW do you hear the fuel pump come On when you turn key to run? Check the EFI fuse/main relay/circuit opening relay
Mar 28, 2008 at 5:15 AM
