1993 Toyota Pickup engine dies
32,800 MILES • 6 CYL • 2WD • AUTOMATIC
CWAYNEMICK
when the engine reaches operating temperature, and I try to drive ,the engine dies. It is worse in reverse, it does it in drive, but not as bad. check engine light works , but has not ever came on. I have noticed a big decrease in fuel mileage since this started. What causes this?
second question--where are the OBD plugs located? I have found the onboard computer but can't find the plugs
Mar 26, 2008 at 2:16 AM
  • 75,988 POSTS
When was the last major tune-up?
The Diagnostic Link Connector is in the engine compartment
Try checking the throttle position and mass airflow sensor-
Mar 26, 2008 at 2:47 AM
