1993 Toyota Pickup Cracked Engine Head
1993 TOYOTA PICKUP
275,000 MILES • 4 CYL • 4WD • MANUAL
GSTONEPAINTING
A new radiator was installed about 2 months ago....would a faulty radiator, or bad installation of, cause a cracked engine head? Never had any coolant leaks or oil....engine filled with coagulated milky brown fluid.
Oct 16, 2009 at 5:55 AM
If the radiator is not passing coolant thru it will cause the engine to overheat and possibly blow the head gasket and crack the head or block
Oct 16, 2009 at 9:50 AM
