1993 Toyota Pickup clutch lockup????
1993 TOYOTA PICKUP
GSX1970
Transmission problem
1993 Toyota Pickup 4 cyl Two Wheel Drive Manual
im interested in buying a used toyota pick, and the owner says the clutch pedal is locked up, would that be the slave cylinder, or any other possible problem??? james
Sep 24, 2010 at 5:01 AM
  • 31,937 POSTS
Hi there,
this will have to be investigated first hand, but if the pedal is locking up with a hard pedal (no movement) this may well be a master cylinder problem or even a problem with the pedal box, to hard to say without seeing first hand.
mark (mhpautos)
Sep 24, 2010 at 5:07 AM
