1993 Toyota Pickup brakes stick
118,983 MILES • 4 CYL • 4WD • MANUAL
SKGRIMES
After the truck warms up the brakes seem to be sticking or after driving for a while the brakes stick causing engine to be sluggish.What could be my problem I have replaced the rotor , pads and replaced the brake fluid.
Jan 5, 2009 at 11:50 AM
  • 75,988 POSTS
Check the brake booster if its leaking it will cause the engine to run rough/idle erractically
Jan 5, 2009 at 12:14 PM
SKGRIMES
egine idles fine and runs fine until the brakes start to stick and then you can notice the lack of engine power and it maybe just one side that sticks.could it be that brake hose or the reservoir cap not ventimg correctly because after I let the truck set awhile the brakes seem to be fine and then they start sticking again.
Jan 6, 2009 at 8:30 AM
  • 75,988 POSTS
Check the brake hose could be collasped internally acting as a one way check valve
Jan 6, 2009 at 8:33 AM
ROSCOP13
My 95 Jeep seems to have a similar issue. Were you able to find the cause or a solution?
Feb 12, 2009 at 2:44 AM
