1992 Toyota Pickup wont idle
210,000 MILES • 4 CYL • 2WD • MANUAL
BIKERDUDE223
92 toyota pickup 2.4 idles extremely rough unless holding the mass air open a quarter to half inch then will rev up and can let mass air go but when let back to idle extremely rough and eventually dies. no check engine light and tried swaping mass air made run perfect for 3 minutes then problem returned. also cant find any vaccum leaks. any suggestions please?
Apr 27, 2009 at 11:21 AM
  • 75,988 POSTS
Check the IACV and TPS to include vacuum leaks between airflow meter and throttle body/EGR valve
Apr 27, 2009 at 12:29 PM
