1992 Toyota Pickup Starter Removal/Installation
140,000 MILES • 6 CYL • 4WD • MANUAL
KOCH9439
I have the Starter mounting bolts and wires removed, how do I get it out of there? There doesn't seem to be room to pull it out, I've twisted and turned it but I don't see a path for it to come out.
Oct 11, 2009 at 12:39 PM
RACEFAN966
  • 5,029 POSTS
You will need to unbolt the exhaust from the manifolds to gain enough room to get the starter out.
Oct 12, 2009 at 7:17 AM
KOCH9439
does it come out from the bottom of the truck?
Oct 12, 2009 at 7:25 AM
RACEFAN966
  • 5,029 POSTS
Well I did find a better way. I remove the passanger tire and then remove the splash guard between the frame and the body. Now you can see the cables unbolt them (make sure battery is disconnected). Now unbolt the starter the lower bolt will have to be done from under the truck then twist and turn and bring the start through the hole that you have with the splash guard removed. Hope this helps better then dropping the exhaust.
Oct 13, 2009 at 2:50 AM
