1991 Toyota Pickup Starter
54,000 MILES • 6 CYL • 4WD • AUTOMATIC
MERRILL BUCK
Locate starter on engine and how to replace.
Aug 31, 2008 at 9:57 AM
KHLOW2008
  • 41,812 POSTS
Hi Merrill,
Follow the battery positive terminal cable and you would be able to locate the starter at its end.
Remove the negative terminal first, then remove the positive battery cable and solenoid wire from starter, followed by the 2 holding bolts and you can get the starter out.
Sep 13, 2008 at 4:52 AM
