1992 Toyota Pickup rapid clicking noise behind right side o
1992 TOYOTA PICKUP
10,000 MILES • 4 CYL • 2WD • MANUAL
JLC2008
My mechanic says this could be a faulty relay switch. It is going to cost me $200 to replace including all the time he took to figure this out. AND he is still not sure that this is the problem. Does this sound right to you?
Nov 24, 2008 at 3:31 AM
93TYPKUP
  • 8 POSTS
did you ever find what the cause was? I have the same model of truck only a 1993, and am having
the same problem.
Steve
Dec 13, 2008 at 4:32 PM
JLC2008
Steve, no i never got a response on this site.
Dec 16, 2008 at 11:46 PM
DOCFIXIT
  • 18,828 POSTS
Is it the right side of dash? if so several relays located there when it is clicking ID which one. post part number anything to help findout which one. Then will advise some electrical problam maybe causing relay to fall out. Any thing at up when it clicks?
Dec 17, 2008 at 1:14 AM
93TYPKUP
  • 8 POSTS
Yes, it's the right side of dash on my '93 Toyota
pickup. unfortunately because of being out of town for the holidays I won't be able to troubleshoot further for a few weeks but will check back in then.
But the thing that does act up when it clicks is the idling----the clicking doesn't occur until almost normally spec'd idle speed (7500 RPM) and then the clicking interferes with the idling, almost making the engine die out sometimes, if I am at a stop. Stuck in awful traffic tonight due to stormy weather, I had to keep revving the engine at stops.
Dec 17, 2008 at 3:02 PM
DOCFIXIT
  • 18,828 POSTS
Believe it to be cut out relay possibably due to TPS out of adjustment.
Merry Christmas
Dec 17, 2008 at 11:06 PM
93TYPKUP
  • 8 POSTS
Hi, back after the holiday break and a bout of shingles. Yes, the clicking module is the COR as shown.
https://images.2carpros.com/forum/automotive_pictures/286195_truck_COR_module_3.jpg
Jan 7, 2009 at 7:39 AM
DOCFIXIT
  • 18,828 POSTS
Then TPS is at fault go to throttle find screw give it a slight turn 1/8. If clicking stops good if not need to replace TPS
Jan 7, 2009 at 7:54 AM
93TYPKUP
  • 8 POSTS
well the 1/8 turn did stop the COR from clicking,
as well as preventing the engine from cutting out.
So now that makes me wonder....the TPS screw had been set in place back in August at a certain point, after I'd had some major work done (new timing chain, valves, airflow sensor) at a shop. So there must have been some sort of "settling" of the system over time? I first noticed the COR clicking occuring sporadically in like October, then it became more frequent after the engine would warm up after use.
Jan 7, 2009 at 9:07 AM
DOCFIXIT
  • 18,828 POSTS
The TPS is a variable resistor and degragation will take place over time
Jan 7, 2009 at 9:14 AM
93TYPKUP
  • 8 POSTS
so might as well replace it sooner than later?
https://images.2carpros.com/forum/automotive_pictures/286195_TPS_adjusted_172009_1.jpg
https://images.2carpros.com/forum/automotive_pictures/286195_TPS_toyota_truck_1.jpg
Jan 7, 2009 at 9:37 AM
DOCFIXIT
  • 18,828 POSTS
Yes a new one might be best . There is a proceedure to set up . If not in instructions with TPS let me know and will provide . Need OHM meter
Jan 7, 2009 at 9:43 AM
93TYPKUP
  • 8 POSTS
Hmmm. Maybe the TPS is further gone than thought. I tried measuring for ANY voltages according to the Toyota manual (shown below), with the ignition switch on, and am not reading any voltage across any of the terminals. ?
https://images.2carpros.com/forum/automotive_pictures/286195_TPS_measurements_1.jpg
Jan 7, 2009 at 11:15 AM
DOCFIXIT
  • 18,828 POSTS
Pull term measure from E2 to ground what do you get? Throttle fully open ohm from VTA to E2 3300 to 10000 ohms
Jan 8, 2009 at 7:40 AM
93TYPKUP
  • 8 POSTS
from VTA to E2 measures 4650 ohms.
Still don't read voltage as per the Toyota chart.
Jan 10, 2009 at 10:21 AM
DOCFIXIT
  • 18,828 POSTS
What did you get from E2 to ground?
Toyoa voltage readings are accurate but are you back probing or removing treminal connector ?
Jan 10, 2009 at 10:32 AM
93TYPKUP
  • 8 POSTS
I have the terminal (harness) disconnected
from the TPS.
Jan 10, 2009 at 10:33 AM
