1992 Toyota Pickup oil temp sensor
159,000 MILES • 6 CYL • 4WD • MANUAL
CURTIS THOMPSON
I need to figure out if replacing my oil temp sensor if it will bring little more life in the get up into the truck. it already had head gasket new plugs, new plug wires, new clutch. but the wire to the oil temp sensor on the side of the motor doesn't stay on so should i just replace the wire and the sensor? It doesn't register any temperature on the oil temp gauge.
Feb 18, 2010 at 4:34 PM
  • 31,937 POSTS
Hi there,
Replace the sensor wire and check that you are getting a reading on the dash, if not replace the sensor, this will not give you any performance improvement at all.
Mark (mhpautos)
Feb 18, 2010 at 5:39 PM
