1992 Toyota Pickup fuel
250,000 MILES • 4 CYL • 4WD • MANUAL
DAN STOLTZ
after replacing a head gasket my 92 toyota pick up with a 22RE ran fine for approx a week then suddendly began to idle up and down. thinking it was a loose intake i retorqued and checked for vacum leak. finding none. now engine will only run for a few seconds and die from no fuel. starting every time it kills after a few seconds.any suggestions
Nov 5, 2009 at 7:26 AM
  • 75,988 POSTS
Check the fuel pressure if its within specs and comeback with your test results we start here.
Nov 5, 2009 at 7:52 AM
