1992 Toyota Pickup clutch problem
28,000 MILES • 6 CYL • 4WD • MANUAL
MIKEEDWARDS1
I recently replaced the clutch in my 1992 toyota v6 pickup that had 270,000 miles on it. After replacing the clutch i found that the transmission wouldnt go into gear when sitting still but would shift properly when going down the road but weouldn't down shift witout grinding. i took the clutch back out to make sure it was in properly and it was. I replaced everything clutch,pressure plate, trowout bearing, and pilot bearing. Also replaced the slave cylinder although it wasn't leaking and worked fine with the old clutch, but still have the same prtoblem.
Aug 17, 2009 at 11:36 AM
WINEBURGER
  • 82 POSTS
i ran into a simmular problem using a brute power clutch assembly on a 98 chevy took it out and got a diffrent brand and it fixed the problem .
Aug 17, 2009 at 11:44 AM
WINEBURGER
  • 82 POSTS
brute power was the clutch that didnt work
Aug 17, 2009 at 11:45 AM
