1992 Toyota Pickup backup switch or neutral safety
1992 TOYOTA PICKUP
96,000 MILES • 4 CYL • 2WD • AUTOMATIC
DREWVB1
Recently my back-up lights have stopped working on my wife's truck.
I checked all of the fuses, cleaned the sockets, bulbs & connectors. Still no power to the rear contacts.
I attempted to replace the backup switch on the trans and I was send a part from Rock Auto that does not appear to match. The rep on the phone @ Rock Auto disagrees. I have attached a pic of their part that I cannot seem to find a place on the tranny for.
The dealer took the VIN # and told me there was NO separate backup switch for the automatic trans and I needed a neutral safety switch instead (@ 10x the cost).
Can you tell me if this model (Tran # 03-71) has a separate B/U switch from the NS switch?
Can you send me a pic with the location?[img:896f343e61]http://www.2carpros.com/forum/automotive_pictures/299596_Rockauto_part_1.jpg[/img:896f343e61]
Jan 10, 2009 at 4:10 AM
With a column shift As per the back-up light-test the back-up relay-see below -Check A and no.14 for pick/up in the fuse/relay block no.1 If unreadable give me your email addy
https://images.2carpros.com/forum/automotive_pictures/12900_back_up_relay_1.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_back_up_relay2_1.jpg
Jan 10, 2009 at 10:55 AM
DREWVB1
Good catch, yes it is a column shift.
It is hard to read and saving it doesn't help. If you could email it directly to me that would be greatly appreciated. My email is aprzybysz@roadrunner.com.
Can you tell me if this part is valid for my auto trans?
Should I send it back?
Jan 11, 2009 at 3:08 AM
Dunno it sure don't look like a relay-
I've sent the EWD
Jan 11, 2009 at 6:20 AM
