Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Pickup
Drivetrain
Transfer Case
Symptoms
Stuck
4 wheel drive stuck in low?
1992 TOYOTA PICKUP
177,000 MILES • 6 CYL • 4WD • MANUAL
MBUNCH33
MEMBER
I HAVE A 1992 TOYOTA TRUCK THAT IS STUCK IN 4 WHEEL LOW...ANY SUGGESTIONS ON HOW TO GET IT UN-STUCK.?
Aug 16, 2008 at 4:36 AM
KHLOW2008
Experienced Mechanic
Hi mbunch33,
Most probably the 4 X 4 gear shift bushes are worn and the gear lever is now out of position.
Remove the 4X4 gearshift and manually use a screwdriver to engage to 2 wheel mode. Don't forget to replace the lever bush.
Aug 17, 2008 at 4:28 AM
MBUNCH33
MEMBER
TRIED TO MANUAL DO IT WITH A SCREWDRIVER BUT IT IS LOCKED IN 4 WHEEL LOW AND WON'T BUDGE.
Aug 17, 2008 at 7:40 AM
KHLOW2008
Hi mbunch33,
You sure you got the correct shift slot?
Any way it requires quite a strong force to get it going and since a screwdriver did not do the job, you need a stronger bar.
Aug 18, 2008 at 1:00 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
