1992 Toyota Pickup
KEVINCRUZ
Engine Cooling problem
1992 Toyota Pickup 4 cyl Two Wheel Drive Manual
hello! I'm have a timing problem. At idle it's 5 degrees BTDC, you touch the gas it goes 40 degrees of advance. At a stop sign it cools down, on the freeway it heats up. I have a new distributor and checked the throttle position sensor. According to the book it's good. Also the mass air sensor checks out good. I also put a new thermostat, water pump radiator cap, and eletric fan on. Any ideas??? Thank you and have a nice day!
Nov 9, 2009 at 11:06 AM
RACEFAN966
  • 5,029 POSTS
Have had the radiator checked to see if it may be plugged or partially plugged?
Nov 10, 2009 at 1:19 PM
KEVINCRUZ
yes the radiator was flushed by a shop
Nov 10, 2009 at 3:15 PM
RACEFAN966
  • 5,029 POSTS
Have you checked the fan clutch? Has the temp been checked to see what it is at the upper hose verses the lower hose at operating temp?
Nov 11, 2009 at 2:02 AM
