1991 Toyota Pickup running poor at idle
1991 TOYOTA PICKUP
188,000 MILES • 4 CYL • 4WD • MANUAL
ZL1CHEVY427
my 1991 toyota pickup 4x4 with a 22re. it runs great when its cold but as soon as it warms up the idle starts to bounce around and starts to mis. half the time when you take off it will spit and mis but once i get the rpms to about 1500 to 2000 rpm it runs great even with it warm. also when i turn on the ac cold or warn it wont engage the clutch unless the rpms are about 1500 so at idle the ac does not work but driving it works great. the cooling fan is electric and its on its aftermarket but it triggers as soon as you press the ac botton thanks
May 13, 2009 at 10:42 AM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
May 13, 2009 at 10:48 AM
ZL1CHEVY427
it has brand new fuel filter also its has msd coil, wires new plugs and cap and rotor.
May 13, 2009 at 10:55 AM
You need to check the rest I've mentioned and come back with some results.
May 13, 2009 at 7:41 PM
