my 1991 toyota pickup 4x4 with a 22re. it runs great when its cold but as soon as it warms up the idle starts to bounce around and starts to mis. half the time when you take off it will spit and mis but once i get the rpms to about 1500 to 2000 rpm it runs great even with it warm. also when i turn on the ac cold or warn it wont engage the clutch unless the rpms are about 1500 so at idle the ac does not work but driving it works great. the cooling fan is electric and its on its aftermarket but it triggers as soon as you press the ac botton thanks
May 13, 2009 at 10:42 AM
