1991 Toyota Pickup replacing clutch
DUNCANSR5
Transmission problem
1991 Toyota Pickup 6 cyl Four Wheel Drive Manual
just replaced clutch, had flywheel turned. after getting back togather cannot get truck into gear. Could they have shaved too much from flywheel
Dec 24, 2008 at 4:08 PM
DOCHAGERTY
  • 9,606 POSTS
Anything is possible. Where did the clutch kit get sourced from? Are the clutch hydraulics to blame? Who installed the clutch? It is highly unlikely the flywheel got shaved so much that it could cause this issue. When you say it will not go into gear, do you mean at all or just when the motor is running?
Dec 25, 2008 at 6:42 AM
