1991 Toyota Pickup Poor Engine Performance
138,000 MILES • 6 CYL • 4WD • MANUAL
JOE GLOTZBACH
The engine has suddenly started running very rough. On the road it will run very rough with little power and then all of a sudden will run normal then all of a sudden will go back to running rough. Checked plugs, plug wires, fuel & fuel filter. All check out OK. If the throttle position sensor (TPS) is unplugged it seems to run much better although not normal. Replace TPS, any suggestions?
Dec 30, 2009 at 8:53 AM
  • 75,988 POSTS
Adjust the TPS or replace it.Check and test the air flow meter.
Dec 30, 2009 at 10:31 AM
