1991 Toyota Pickup oil level
147,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOB1890
This vehicle calls for 4.5 qts of oil with filter. When I change oil and add this amount, the oil stick only registers to the "add oil" mark. Is this common? If not what could cause this?
Aug 10, 2009 at 12:25 PM
  • 31,937 POSTS
Hi there,
You may have a wrong dip stick in the engine, if you are sure that you have added the correct amount of oil for your engine, it will be ok, if you can try and locate another dip stick and try that one to see where it registers on the stick.
Mark (mhpautos)
Aug 10, 2009 at 1:19 PM
