1991 Toyota Pickup ignition timing
1991 TOYOTA PICKUP
GAUNA82
Engine Mechanical problem
1991 Toyota Pickup 4 cyl Two Wheel Drive Manual 170k miles
what is the ignition timing for 1991 toyota pickup and the idle speed for the same engine
Sep 12, 2008 at 4:52 PM
5deg BTDC @ 750-850 rpm make sure you jumper Te-1 to E-1 on the diagnostic check connector when you adjust it the rest is done by the computer.
Sep 12, 2008 at 11:05 PM
