how to replace a thermostat
1991 TOYOTA PICKUP
256,000 MILES • 6 CYL • 4WD • MANUAL
JBUG21
hey guys i just wanted to know exactly how to change the thermostat on my pickup?
Sep 2, 2009 at 5:05 AM
Here is a guide to help walk you through the steps and diagrams below to show you how on your car. The bottom hose attaches to the thermostat housing
Sep 2, 2009 at 7:34 AM
JASONLEEBRIGGS
The thermostat froze closed and the radiator overheated and cracked. I replaced the radiator and the thermostat.
Overheating is still a problem. I removed thermostat and truck stays cool. I opened the radiator and water is moving (meaning water pump is working?). I replaced thermostat again with a new one and still overheats.
Could new radiator and thermostat be rated at different temps? Do i keep getting bad thermostats?
Jan 5, 2019 at 4:25 AM (Merged)
MISSY2SHOES
try flushing your system. You may have a blockage in the heater core. Dont make the mistake of putting your thermostat in backwards, And yes can be done.
2CP-ARCHIVES
  • 4,540 POSTS
where is the thermostat located on a 91 4
wheel drive Toyota pickup
Jan 5, 2019 at 4:27 AM (Merged)
KHLOW2008
  • 41,814 POSTS
If you follow the upper radiator hose to engine, you would come to the thermostat housing, inside which is the thermostat.
FLOPSTER54
Engine Cooling problem
1992 Toyota Pickup 6 cyl Four Wheel Drive Automatic
Hello there, I can't find thermostat. Do you know where it is?
The thermostat is located in the thermostat housing at the bottom radiator hose where it connects to the engine block.
https://images.2carpros.com/forum/automotive_pictures/12900_stat_5.gif
DRAIN ENGINE COOLANT DISCONNECT RADIATOR OUTLET HOSE REMOVE THERMOSTAT (a) Remove the 3 nuts. water inlet and thermostat with gasket from the water pump. (b) Remove the gasket from the thermostat.
NETERONE
i need to know the location of a thermostat on a 1992 pickup 2wd 4 cylinders thanks.
  • 55,423 POSTS
The thermostat for these engine is in the bottom radiator hose as well. Under the thermostat housing at the block.
KEVINJOE
1993 Toyota Pickup 6 cyl Four Wheel Drive Manual
need to know where thr thermastat is located
BLUELIGHTNIN6
  • 16,542 POSTS
the thermostat is in the bottom radiator hose where it connects to the motor.
