1991 Toyota Pickup engine problem
ZACH1981
Engine Performance problem
1991 Toyota Pickup 4 cyl Two Wheel Drive Manual
what's wrong if the truck sounds like it's miss firing
Sep 21, 2010 at 12:46 AM
  • 75,988 POSTS
It probably needs a major tune-up, when was it? also do you have a check engine light
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Sep 21, 2010 at 1:54 AM
