1991 toyota 4x4 4 cylinder 140000 miles
WES 34
the truck set up for about a year. When i tried to start it would not start. The fuel pump is not getting any fire to it. I can run a hot wire to it and it will start. the only fuses i can find are marked EFI one is a relay the other a 15 amp fuse the both are ok. Is there something else i can check? I cannot find a break in the wire i have traced into to the firewall from the pump forward I lose it after that. please help!
Feb 11, 2007 at 12:12 PM
  • 75,988 POSTS
Try this get a small jumper wire find the diagnostic check connector jump Batt and Fp together-does the truck starts. Comeback am not done.
Feb 11, 2007 at 8:24 PM
WES 34
Tried that Nothing the fuse marked engine in the truck is dead also
Feb 13, 2007 at 6:39 AM
  • 75,988 POSTS
The engine fuse powers the ignition circuit/fuel injectors -you got to find what caused it to popped. Repalce it-does it blow?
About your power to the pump it has to go thru the circuit opening relay than thru the MAF meter Fc circuit than to the pump.
Also check whether it has a fuel pump relay/something Toys don't have it.
HTH-Good Luck!
Feb 13, 2007 at 8:16 AM
WES 34
The fuse was not blowed there is not any power to it
the relay is hot the EFI fuse is hot. could a bad ignition cause this?
Feb 13, 2007 at 3:41 PM
  • 75,988 POSTS
At the engine compartment positive cable look for the power distribution box-inspect all those little square boxes fusible links-then comeback
No power there-the igntion system is dead/injectors.
Try this at the coil-connect a wire to the positive terminal and take it straight to the positive term. of the battery. Now go try and attempt to start the p/up.
Feb 13, 2007 at 4:43 PM
