1990 Toyota Truck
GEOBJ
I have the 2.4 litre engine, with around 166k. The speedometer has stopped working, so I disconnected it from the transmission and spun the shaft, and the speedometer registers. Is the cable splines worn, or is ther something else in the transmission?
Jun 28, 2006 at 1:27 AM
  • 75,988 POSTS
put it back in make sure its align properly and push it all the way in before you tighten the bolt and retry
Jun 28, 2006 at 12:48 PM
GEOBJ
Have done that several times now, always rechecking the speedo cable, figured its the weak link. Is the driven gear anything that can wear out?
Jun 29, 2006 at 12:54 AM
