1990 Toyota Pickup no power and idles rough about 200 - 400
21,000 MILES • 4 CYL • 4WD • MANUAL
ALVAREF
No power. can just barely make 55 mph on highway and have to get there extending rpm in 3rd and 4th gear. can floor the accelarator and not get any increase in rpm or speed and then seems to begin to lose speed. slightly pull back on pedal and rpm and speed holds or returns to 55mph. no power to climb small incline.
changed fuel filter, spark plugs, spark plug wires, air cleaner. gapped open flange at catalytic converter to ensure not plugged. ran injector cleaner in fuel tank twice, poured sea foam in crankcase no change. cannot find any leaking vacuum hoses.
Jun 11, 2010 at 7:57 AM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 11, 2010 at 1:36 PM
