1990 Toyota Pickup left brake light does not work
226,000 MILES • 4 CYL • 2WD • MANUAL
BJQUINN927
The left brake light on my 1990 toyota Pickup quit working. I replaced the bulb and checked the fuses. This still did not fix the problem. The rest of the lights work fine. What could be the problem and how can I fix this before I get pulled over for having a brake light out.
Mar 5, 2009 at 10:00 AM
  • 75,988 POSTS
Check the green and white wire where it ties up with the right rear brake light and make sure there's no corrosion on the socket
Mar 5, 2009 at 10:08 AM
