1990 Toyota Pickup left brake light does not work
1990 TOYOTA PICKUP
226,000 MILES • 4 CYL • 2WD • MANUAL
BJQUINN927
The left brake light on my 1990 toyota Pickup quit working. I replaced the bulb and checked the fuses. This still did not fix the problem. The rest of the lights work fine. What could be the problem and how can I fix this before I get pulled over for having a brake light out.
Mar 5, 2009 at 10:00 AM
Check the green and white wire where it ties up with the right rear brake light and make sure there's no corrosion on the socket
Mar 5, 2009 at 10:08 AM
