1990 Toyota Pickup HELP! Slipping out of gear
1990 TOYOTA PICKUP
300,000 MILES • 4 CYL • 2WD • MANUAL
PJFLORES
I have a 1990 Toyota 4 speed manual pickup. Recently, it has been slipping out of 1st and second gear. I had the engine rebuilt about 30k miles ago and also replaced the flywheel and the clutch disk at that time. The problem is getting progressively worse. Please help with ideas. Thanks!
Sep 27, 2009 at 3:12 AM
JLHOWARD
my 91 pickup use to do the same. I took to a garage and they repaired it by replacing a plastic peice that guides the shifter into gear. the part was about $15.00 and labor was about $100.00. it took onlly half a day to fix.
Oct 28, 2009 at 12:58 PM
