1989 Toyota Pickup wont shift into 1st 3rd or 5th
200,000 MILES • 6 CYL • 2WD • MANUAL
SKYLER
well my truck wont shift into 1st 3rd or 5th. my stick shift bushing broke an i replaced it an it did not fix the problem. its like there isnt enough reach to go into gear. im wondering if my stick shift bent an cant make the travel to the upper gears. i took my stick shift out an i could shift into 1st 3rd an 5th with no problem with the other side of the stick shift. what do u think is the problem??
thank you a head of time.
Mar 26, 2008 at 1:21 PM
  • 75,988 POSTS
. i took my stick shift out an i could shift into 1st 3rd an 5th with no problem with the other side of the stick shift. what do u think is the problem?? If you can put it in1/3/5 better investigate-something is wrong shift linkages or the striking rod or internal sticking and jamming of gears-
Mar 26, 2008 at 1:53 PM
