1989 Toyota Pickup oil pan removal
BOBGRIM
1989 Toyota Pickup 4 cyl Four Wheel Drive Manual
can I remove the oil pan towards the rear of the vehicle or do I need to remove he steering linkage and take it out the front? (or pull the pan over the linkage). If I need to remove the linkage, what is the best way and best joint to remove?
Aug 17, 2009 at 11:42 PM
BLUELIGHTNIN6
  • 16,542 POSTS
you will need to detach some of the linkage
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_845.jpg
what model is this and is it petrol or diesel?
Aug 18, 2009 at 5:36 AM
