1989 Toyota Pickup fuel
1989 TOYOTA PICKUP
189,000 MILES • 4 CYL • 4WD • MANUAL
MRBRAGG
I have put new fuel pump AND new relay on the truck an it will not crank STRAIGHT wired fule pump it worked an the truck cracked up but runs like crap check the connections all good any other things to check
Jan 24, 2008 at 3:52 AM
Check the fuel pressure and also the idle air control valve/PCV valve and the EGR valve. Last for vacuum leak
Jan 24, 2008 at 4:49 AM
