1989 Toyota Pickup Fast idle high
DRZ
  • 1989 TOYOTA PICKUP
  • 6 CYL
  • 4WD
  • MANUAL
  • 118,000 MILES
My 89 toyota sr5 pickup when started cold runs about 2100 rpm throttle stop screw and tps are adjusted I have looked for vacuum leaks This is the orignal throttle body on a reman long block, its runs at 2100 for about the first 6 min. Then drops down to 800 with the idle speed adjusting screw all the way in
Thursday, January 24th, 2008 AT 12:12 PM
Check the cold start injector time switch
Thursday, January 24th, 2008 AT 12:38 PM
DRZ
I can unplug the cold start injector and it makes no differents
Thursday, January 24th, 2008 AT 7:30 PM
Check the throttle position sensor closed/wide open throttle. When you're adjusting the mininum air-did you ground the diagnostic check connector?
Thursday, January 24th, 2008 AT 7:35 PM
