Idle speed
100,000 MILES
SOLA MECH
The vehicle idle speed too fast
Apr 4, 2017 at 1:45 PM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and iac hole with choke cleaner then check for a vacuum leak. if it continues scan for codes
Apr 5, 2017 at 12:09 AM
STEVE W.
  • 15,378 POSTS
As HMAC says, clean those parts, also check for any vacuum leaks as those will also cause a high idle. A stuck or failed IAC (common on some Toyota engines) will also cause this. They are not hard to clean but they can be difficult to remove depending on which engine you have.
Apr 9, 2017 at 6:40 AM
