1989 Toyota Pickup A/C clutch removal
26,000 MILES • 6 CYL • 2WD • MANUAL
MICHAELHYDE
How do I remove the clutch from my A/C compressor? I have the radiator removed for timing belt replacement.
Mar 30, 2009 at 1:19 PM
JAMES W.
  • 2,394 POSTS
There is a 13mm nut in the clutch hub center that holds it to the shaft. But, it takes a special puller to remove the clutch hub from the shaft.
Mar 30, 2009 at 3:35 PM
