1989 Toyota Pickup
CJJO13
  • 1989 TOYOTA PICKUP
Transmission problem
1989 Toyota Pickup 6 cyl Four Wheel Drive Manual 15?K miles
my truck will not go into gear when running (will go into all gears and R when not running). When I start it and it's in gear, it lunges forward and then keeps crawling even with the clutch pedal down. I have replaced the slave and the clutch master cylinder already and bled it well, is there anything else I can maybe do before having to drop the tranny and go internal? Please HELP!
Monday, May 5th, 2008 AT 10:55 PM
  • 31,937 POSTS
Hi there,
The clutch is not throwing far enough, first check for excessive clutch pedal free play, you will only need a mm or 2 free play, next make sure it is bleed correctly. If the problem is still evident you may have a pressure plate problem.
Mark (mhpautos)
Tuesday, May 6th, 2008 AT 4:47 AM
