1988 Toyota Pickup Rough Idle and Hard Start When Warm
258,000 MILES • 6 CYL • 4WD • MANUAL
88TOYOTADELUXE
Motor was replaced last year.Truck idles rough and misses at steady throttle after it has warmed up if I can get it started. Starts and runs fine when cold (closed loop). I been watching fuel pressure during these episodes seems to maintain around 46 p.s.i., although I do not get fuel pressure with key on engine off (prime) as per the manual. Also if it's cranked enough it will occasionally catch and start. I've found that by removing 1 of the injector wires it will start right up just on 5 cylinders. At this point I am leaning towards a bad MAF since the problem only occurs when the engine is warm But I'm not certain.
Jan 31, 2008 at 11:23 AM
TOYOTADOG
[quote:6287df27f9="88toyotadeluxe"]Engine problem
1988 Toyota Pickup 6 cyl Four Wheel Drive Manual 258000 miles
Motor was replaced last year.Truck idles rough and misses at steady throttle after it has warmed up if I can get it started. Starts and runs fine when cold (closed loop). I been watching fuel pressure during these episodes seems to maintain around 46 p.s.i., although I do not get fuel pressure with key on engine off (prime) as per the manual. Also if it's cranked enough it will occasionally catch and start. I've found that by removing 1 of the injector wires it will start right up just on 5 cylinders. At this point I am leaning towards a bad MAF since the problem only occurs when the engine is warm But I'm not certain.[/quote:6287df27f9] maybe try your idle sensorand try changing the plugs if it missesif it is idleing to low then sometimes it will knock and if it idles a little hight it is a bit rough but that an easy fix.
Feb 10, 2008 at 1:48 PM
