1988 Toyota Pickup It aint working
208,000 MILES • 6 CYL • 4WD • MANUAL
SPWIBORG
I just got this pickup for $250 it worked great for 2 days. Ive put around 200 miles on it. All of a sudden Im drivin down the road and I go to go up a hill and I got nothin. It was almost like I was holdin in the clutch but I wasnt. I can get a little movement in reverse but that is at 7000 rpms. The shifter moves all over like im pushin the clutch. Is my clutch shot or is it some other problem?
Aug 1, 2009 at 4:26 PM
  • 31,937 POSTS
Hi there,
do you have clutch pedal pressure? Can you select the gears as normal? ids the any noise whey you release the clutch in gear?
mark (mhpautos)
Aug 1, 2009 at 5:17 PM
