1988 Toyota Pickup head lights
36,000 MILES • 4 CYL • 2WD • MANUAL
JROD RACING
my head lights are too dim and when I turn on the hi beams, the head lights go off.
i all ready install new head lights on, what do i do to fix the problem
Oct 31, 2010 at 10:31 AM
  • 75,988 POSTS
Check the ground circuits
Oct 31, 2010 at 10:55 AM
JROD RACING
[quote:35b9221e6f="rasmataz"]Check the ground circuits[/quote:35b9221e6f] no luck w/ chaking the ground wires i add more ground wire to the battery ann still the same but i found a green wire (toste) the go to the tail lights from the relay on the kick panel but tail ligths work good what you think is the problem w/ the hi ligths Mr.
Nov 2, 2010 at 9:40 AM
  • 75,988 POSTS
The green wire does it have a red tracer wire if so -it goes to the high beam circuit
Nov 2, 2010 at 10:38 AM
