1988 Toyota Pickup fuel injectors
1988 TOYOTA PICKUP
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
COUNTRYLOVE347
truck will start but won't stay running, acts like injectors are not working can't find any fuses blown.
Oct 14, 2009 at 7:10 AM
Check the fuel pressure if okay -check and test the idle air control valve, throttle position sensor and airflow meter.
Oct 14, 2009 at 7:15 AM
COUNTRYLOVE347
[quote:4cece75ff9="rasmataz"]Check the fuel pressure if okay -check and test the idle air control valve, throttle position sensor and airflow meter.[/quote:4cece75ff9]got pressure, how do you test the sensors?
Oct 14, 2009 at 7:29 AM
What was the actual fuel pressure?
Oct 14, 2009 at 7:31 AM
COUNTRYLOVE347
[quote:95a1b50911="rasmataz"]What was the actual fuel pressure?[/quote:95a1b50911]don,t have actual pressure,just opened line and turned over motor
Oct 14, 2009 at 7:43 AM
EFI system don't like low fuel pressure-You need a fuel pressure gauge to determine it report back with the readings so that we can continue to assist.
Or you can try cleaning out the idle air control valve and see what happens
Oct 14, 2009 at 7:47 AM
