1987 Toyota Pickup toyota pickup brakes
1987 TOYOTA PICKUP
20 MILES • 4 CYL • 4WD • AUTOMATIC
JAMESPHELPS007
i put new brake lines that run from the front to the back of my truck along with a new master cylander i cannot still get them to pump up they will for about a minute or if you keep pumping them im lost never had this problem before
May 26, 2010 at 1:55 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check vacuum power assist servo to see if vacuum is leaking
May 26, 2010 at 2:07 PM
