Engine Mechanical problem 4 cyl Two Wheel Drive Manual 198000 miles
I bought a tester to see if there is spark from distributor to sparkplug, i have not seen spark. I took the distributor cap off a bit dirty and a bit worn inside, aswell as the rotor, but the rotor cleaned up nice (sand it down a bit). Anyways just to make sure bought new cap and new rotor. I followed book instructions and 2car instruction to see if the distributor is getting voltage in the ON position by testing the 2 small wire that go to the distributor. im getting reading of .65 something. after replacing and checking for spark nothing
Do I need new wires ? how can i test them
I read a resistance test, but dont have a tester for ohms and dont know what steps to take
stuck with no spark. i can smell gas
new headgasket and timing chain done to toyota 22r specs
Jun 12, 2009 at 11:18 AM
